CWSOLUTIONS
Runtime Error
Program: Minicad v7 + updates
Iam receiving the Error,
"Run Time Error!"
"Path points to Minicad.exe"
abnormal program termination
Now i have done some research into the topic, people have suggested to replace the MSVCRT.DLL VB file, upon replacement windows is unable to load and i must revert back to the old .DLL i have also tried the following;
Re-install VB files - Failed - "File is currently in use error"
Re-Install program - Failed "Same Error"
Re-associate vbfiles with reg32 command - Failed "same error"
Updated to current version - Failed "same error"
"System restore" - Failed
I have also tried Microsoft suggestions;
support.microsoft.com/kb/192123/EN-US
support.microsoft.com/kb/221946/EN-US
Which describes updating libraries (including the C runtime)
I have also attempted a number of other things with no success; event viewer shows no program failure in logs.
Specs;
P4 toshiba notebook (Program not too hardware dependant / not an issue)
Winxp sp2 - Upto date (most current)
Usual programs, Sunjava, adobe, etc...
Please note, this is a cleanly formatted machine, there is no spyware / virus infections
Any suggustions would be greatful, i have been trying to fix this problem for over a week!
Timothy
7 answers to this question
CW,
Sounds like you have gone through a lot of time and effort so far. Have you considered simply upgrading to VectorWorks 12? May be worth it in the long run for many reasons, not the least of which you can start drawing rather than going through trying to fix this problem......???
Well, that's a crappy solution. I'm having the same issue. I just installed Minicad 7 on a Windows XP machine and am getting the same results. I'm wondering if Minicad 7 is not XP compatible.
You're talking about a program written 7-8 years ago, it absolutely wasn't tested on XP. I don't think you would find any company that would support software that old. That being said I think Peter's advice is very good.
Perhaps you should try Version 6? Or maybe going back a little further to a pencil and vellum. That always seems to work no matter what system you are running wink.gif
Seriously though, you need an older OS to run it like Win98.
I know this is a really old thread, however I am running into the same issue and would like to know if anyone came up with a solution for the issue.
I know for a fact that MiniCAD 7 runs in Windows XP. I have ran it in Windows XP for the last few years at my school in the lab. I started to create my new image for the next school year, and before installing the software I ran all windows updates. Once that was complete I started installing Applications. After that I started testing them and found that MiniCAD would no longer run, giving me the same error as above.
So I took a computer that had last years image on it (Windows XP SP2), but didn't have MiniCAD installed, and it loaded, and launched perfectly fine. So I guess it looks as though there is a conflict with some of the Windows Updates that have came out in the last year that is causing MiniCAD to no longer run.
Does anyone have any ideas other then upgrading to Vectorworks 12? That simply will not happen. The teacher that teaches this program only uses MiniCAD 7 because he knows it. If he has to learn something new he will have to learn AutoCAD because, AutoCAD is Ministry Licensed, and we will not have to pay for it, where upgrading to a new version of Vectorworks will cost quite a bit.
Thanks for your time.
Just an update..
I took one of the systems that had last years image one, which MiniCAD 7 worked on, and did all of the Windows Updates from over the year, and MiniCAD continues to run.
So it appears that one of the new peices of software that has been added to the image since last year is causing this issue. That's what I have conluded anyway.. I will look through the new software install and see if it might be the cause. I wonder if having AutoCAD installed is causing this..
I've had the same problem ever since starting to use WinXP and it is definitely not a conflict with AutoCAD.
I've been keeping an old machine running Win98, just so that I can keep using MiniCAD. It is a fine program. Don't want to upgrade. Would REALLY like to find a fix for this.
