emdub 0 Posted January 16, 2006 Did this: STEP 1: http://www.aladdin.com/support/hasp.asp Choose: Hasp4 End User STEP 2: http://www.aladdin.com/support/hasp/hasp4/enduser.asp Then Choose the following update: NEW! Mac OS X driver installer for OS X.4 (Tiger) OS X HDD_Installer_MacOSX_Tiger_only.zip 730 KB 1.8 05/2005 Still doesn't work. I need very urgent help with this... Quote Share this post Link to post
0 Guest Posted January 17, 2006 Make sure the dongle is NOT pluged in while downloading and running the installation. You do have to extract the zip file and install the file inside the zip file. Quote Share this post Link to post
0 Guest Posted January 20, 2006 OH I just noticed this - VW 10 is not signed off as compatible with Tiger. If you use Tiger, you should be using VW 11.5.1 or later. Quote Share this post Link to post
0 emdub 0 Posted January 25, 2006 Everything works now. Even with VW10 on 10.4.4. It was a case of deleting the preferences file and reopening VW to generate a new one. Quote Share this post Link to post
Did this:
730 KB 1.8 05/2005
