LarryAZ
Can't see dongle
I just installed Tiger and it's upgrades on my backup firewire drive so I could test it before I put it on my main drive. I installed VW 11.5.1 as well and now VW won't launch. It says it can't find the dongle. The dongle is there but the little red light is not on.
When I reboot back on the main drive running 10.3.9 everything works just fine.
Help...
20 answers to this question
Hi,
I installed VectorWorks 12 fundamentals/RenderWorks on a MAC last week.
The installation instructions indicated ?Do not insert dongle until instructed to do so? unfortunately no prompt came and on start up the program could not open as no dongle was present.
This leaves the user in no-mans-land.
I had experienced a similar scenario when installing 11 on a PC and visited the appropriate website for a driver. (No details of this site are included with the software)
www.aladin.com/support/hasp/default.asp
select HASP HL
Am I unlucky or is this a regular feature of VectoWworks installations?
If so this needs to be addressed as first impressions count, never more so than when installing ?1000+ software in front of an new customer.
Dick Berge
(User since 1995
You will only be able to run VW on the primary drive.
Thanks Katie,
but when I boot up on the fire wire drive it becomes the primary drive. As the primary drive it still doesn't work.
Hi Larry,
Go to
www.aladin.com
click on HASP HL
on next page in right hand column under 'How to Buy' click on Support & Downloads
on next page click on to End Users
the following page brings up a table from which you can select your operating system.
Good luck!
Berge,
I found the problem with the web site. Aladdin has two d's. That other site thought a hasp was a hinge.
Anyway, I downloaded the driver and installed it along with the 10.4 patch. Still no light in the dongle and VW can't see it.
Must be a VW file missing. It works just fine when I boot back over to my internal drive.
Berge that addess doesn't work for me. Did it give a file that needed to be moved into the system folder?
This is my backup drive and I just copied the whole VW folder to the drive so I'm guessing I need a file that wasn't in the applications folder. I could do a full install but then I have to go thru the multiple upgrade stuff.
Thanks
Katie,
Can you tell me what file I need to add to the system folder to make it see the dongle?
Thanks,
You may have to boot up to the firewire as your primary and install the dongle driver. Most of the dongle driver files are hidden files.
Katie,
I did exactly that. Booted up on the firewire drive and installed HaspLM drive for 10.4 and the LM Hotfix. Then rebooted and the dongle light didn't come on.
Do I have to do a complete install of VW 11 with all the upgrades to get a file I'm missing or should the dongle install be enough?
Thanks,
The dongle install should be enough.
I'll have to contact Aladdin about this on Monday when I am back in the office.
Katie,
I reinstalled Version 11 on the booted Firewire drive and still no dongle light. When booted in 10.4 this is my primary drive.
Help...
I had the same type of problem and got it fixed recently.
I am a teacher and have an academic version hasp.
I don't know if that makes any difference.
I went to this web address.
STEP 1: http://www.aladdin.com/support/hasp.asp
Choose: Hasp4 End User
STEP 2: http://www.aladdin.com/support/hasp/hasp4/enduser.asp
Then Choose the following update:
NEW! Mac OS X driver installer for OS X.4 (Tiger) OS X
HDD_Installer_MacOSX_Tiger_only.zip
730 KB 1.8 05/2005
( Currently the 7th update on the list)
You could try to start at STEP 2, but I thought I'd give you STEP 1 in case you had a problem.
GOOD LUCK
Brunello you were right! I'm finally running with Tiger.
That wasn't very obvious was it.
Thank you for figuring this out!!!!!!!!!!!!
I am a new user (student) and had the exact same problem as Berge (member 6701). I followed Brunello90's advice above and it worked for me too. Too bad Nemetschek doesn't provide this information with the Install CD's. As someone else mentioned, it leaves a bad initial impression on customers when the customer has to figure out how to install the product from a posting board.
Larry -
Out of curiosity, what dongle driver had you been installing?
I assume (sorry) that you had downloaded the Tiger driver based on the prior conversations.
Hi Brunello
fantastic .... it works !
I just got a new mac and used the migration assistant when I got it out of the box .... it coppied everything over but the dongle light was not on and VW could not see the dongle ... dut did what brunello suggested and hey presto it works
Klaus -
Download the dongle driver from aladdin.com
When installed, do not have the dongle plugged in.
When using the migration assistant, hardware drivers are not installed. In some cases, even software does not "migrate" well and has to be reinstalled.
Followed ALL the instructions on here.
The light on the dongle is red, but VW 10.5.1 quits saying there is no dongle attached.
Sys version: 10.4.4
