cbaarch Posted June 29, 2004 Share Posted June 29, 2004 running 4 serial numbers of VWA 11.0 2 on XPPro and 2 on win98se all the mcd files are stored on 1 hard drive which is shared as 1_Shared CAD files the shared folder is then mapped as a drive on each box 1. do I need to enter all 4 serial numbers on each box? and 2. We have 1 file that gives error -49 ......-FSOPEN when trying to open with only 1 license open at a time. to recover I copied the file to a new folder and it opened tried to "save as" using same name - and got the FSOPEN error "saved as" with a new name and it worked. I can we avoid the FSOPEN problem??? Quote Link to comment
0 Guest Posted June 30, 2004 Share Posted June 30, 2004 The -49 error is either because the file is open on another computer, the file is located on a CD, or the file only has read permissions rather than read/write. You should only install one serial number per computer, but you can add all 4 on all 4 computers. Quote Link to comment
cbaarch
and it opened
1 answer to this question
