inoti
Runtime error_MS VisualC++
Have installed vectorworks 8.01 on PC system Pentium4 2400 (Windows 2000, SP 3)
Installation appears to work fine.
On first program launch error message (Runtime error, microsoft visual C++ ...) pops up. Program window doesn't even open.
The same install works normal on my processor Pentium 3 /1000 MHZ.
Thanks for any help.
Regards Antony
1 answer to this question
THere are a number of things that can cause that.
First- you should get 8.5.2 from Customer Service by contacting them at 888-646-4223 or sales@nemetschek.net.
If you do not have a default printer installed, do so.
If you do have a printer set up in the printers folder -check to make sure a newer driver is not available at the manufacture's website.
If there is a newer version driver, download and install it and then set it up in the printers folder.
If that doesn't work - you may need to insall an internet browser. If you have MS Internet Explorer as the browser, you probably need to update that to IE 5 or 6.
