pedro
faliure to update
i downloaded the VW 9.5.3 update and i get the error message
" An unexpected error occured while installing 'vectorworks'.
1008:17,-4"
has this happened before? i followed the instuctions... turned off all the other apps, left the browser on...
do i need to be running osX.2 before i update VW?
appreciate the time.
pedro
2 answers to this question
I used the 9.5.3 updater and it ran very quickly and said it insatalled correctly. I then check it in the about vectorworks menu and saw that it did not update. this happen to me when i used the 9.5.2 updater. tech support said to reinstall vectorworks run it once and then run the updater which i did and then it worked fine. so i guess i will do the same with the 9.5.3 updater and see if that helps. kind of a pain but waiting around for tech support took two days. installing vwks again took about 15 minutes.
i have to reinstall for the upgrade!?!? oookkaaaaayyy....
i'll give it a shot. thank you.
