9.5.1 install on OSX
Randolph Laub
I have tried to install the 9.5.1 on OSX with the following message: "other components of this installation could not be found. Please run the master setup file, this installation cannot be run on its own". I have version 8.5 installed on OS 9.2. How do I proceed? Should I have been sent an earlier version prior to 9.5.1?
Look forward to reply.
1 answer to this question
Randolph,
This is a incompatibility between our installer, and MacOS X 10.1.4. While we are currently working on a new CD revision to correct the problem, there is not a full OS X workaround.
To get VectorWorks installed, you will need to reboot into MacOS 9 and in stall VectorWorks 9.5.1 from there. Once that install is complete, you may restart back into OS X and use VectorWorks as a full native application.
Matthew GiampapaNNA Technical Support
