Hugo
Lost Architect plugins after updating to 9.5.0
When I was trying to use the setup assistant and many other tools from my VW Architect installation, I noticed several ones couldn't be used and a message appeared telling me "not in the plugins folder". Surprisingly, they were inside that folder. In the menus several tools apperaed grayed out with a message saying they were not in the plugins folder. This happens in either Mac OS 9.2.2 or Mac OS X 10.1.3
I deleted everything and reinstalled:
1 Installed VectorWorks 9.0.12 Installed Architect 9.0.13 Installed RenderWorks 9.0.1
All this under Mac OS 9. Everything worked fine, with all the plugins available.
But then I upgraded to 9.5.0 and a message says the installation was succesful. But I launch the application, it starts fast and with no problem, but... again!!! The architect menus are grayed out and I can't use several tools because of this mesage about the plugins not being in their folders, although they are!!!
I've tried upadting to 9.5.0 in both 9 and X and always have the same problem.
What can I do for a correct installation? Should I copy the 9.0.1 plugins to the 9.5.0 folder or something like that?
My computer is an iMac 400 with 384 MB of RAM running both 9.2.2 and 10.1.3
1 answer to this question
When you upgrade from 9.0.1 to 9.5 make sure to use your Architect, (Not Vectorworks) and Renderworks serial numbers.
