Stairs Tool
When I try to insert stairs into my 2D drawing using the stair tool in
the "scenic Objects" palette, they don't insert.
When I click the first time, it anchors, and goes into rotate mode. when
I click again to set, the outline disappears.
Any suggestions?
Thanks,
Nick
[ 07-23-2003, 12:56 AM: Message edited by: lightnb ]
You will need to set your class options to Show Others. The stairs are automaitcaly placed in a class (Vert-Trans-Main ?). Once they are placed you can change the class. This problem has been fixed for the next release.
Thanks.
I knew it had something to do with layers or clases... just wasn't sure what.
under > organize> class options> show others
didn't fix the problem.
I went to "Layers..." under the organize menu, and changed the "Vert-Trans-Main" layer to 'visible'.
After this, about 100 stair cases showed up. (all the times I had tried to place one, and it didn't work.)
Thanks again,
Nick
