lightnb Posted July 23, 2003 Share Posted July 23, 2003 When I try to insert stairs into my 2D drawing using the stair tool in the "scenic Objects" palette, they don't insert. When I click the first time, it anchors, and goes into rotate mode. when I click again to set, the outline disappears. Any suggestions? Thanks, Nick [ 07-23-2003, 12:56 AM: Message edited by: lightnb ] Quote Link to comment
Vectorworks, Inc Employee klinzey Posted July 23, 2003 Vectorworks, Inc Employee Share Posted July 23, 2003 You will need to set your class options to Show Others. The stairs are automaitcaly placed in a class (Vert-Trans-Main ?). Once they are placed you can change the class. This problem has been fixed for the next release. Quote Link to comment
lightnb Posted July 24, 2003 Author Share Posted July 24, 2003 Thanks. I knew it had something to do with layers or clases... just wasn't sure what. under > organize> class options> show others didn't fix the problem. I went to "Layers..." under the organize menu, and changed the "Vert-Trans-Main" layer to 'visible'. After this, about 100 stair cases showed up. (all the times I had tried to place one, and it didn't work.) Thanks again, Nick Quote Link to comment
