Inigo 0 Posted December 21, 2005 In past versions, setting worksheet line attributes to none allows the worksheet border to dissapear. In 12, the outlines print despite the line value set at "none." perhaps there is a a new worksheet setting? Quote Share this post Link to post
0 Guest Posted December 26, 2005 Click in the upper left corner in the worksheet on the little arrow and select Format Cells. There's a tab called Border. Set this to none and click OK. Now the worksheet should print correctly. Quote Share this post Link to post
0 J Windsor 0 Posted March 7, 2006 I'm also having this problem. Even after editing the worksheet, selecting all cells, and formatting the cells with a border of "none" the lines still show up. I also tried selecting the worksheet object on the design layer and setting the fill and stroke to none. This didn't help either. Perhaps this has been addressed in 12.0.1? I cannot download that update due to our firewall. Quote Share this post Link to post
0 J Windsor 0 Posted March 8, 2006 I found a way to get only the grid lines specified by the Format Cells > Border. In Preferences for the worksheet, uncheck "show grid" in the Display section. I'm not sure how to specify a particular line weight for the borders, however. Quote Share this post Link to post
0 Ken 0 Posted April 15, 2006 I've recently upgraded from 11.5.1 to 12.0.1, and this is indeed broken. Worksheet Data as an object prints with greyish faint outline as a ghost object glitch. It is not printing properly with a 0.00 line weight. On-screen appears unchanged from 11 and seems okay -- i.e., some cells take "bottom border" while others remain without border, so Format Cells seem to work okay -- that is NOT THE ISSUE. It's some kind of printing glitch, perhaps related to how everything feels sluggish and choppy when zooming and panning. Quote Share this post Link to post
0 Hugues 156 Posted April 21, 2006 The workaround for this problem is to turn off the Quartz imaging preference when printing. Quote Share this post Link to post
