I am supporting a registered user of VW10.5 running on MAC OSX 10.3. He has an HP DeskJet 1220C printer that worked fine when directly connected to the MAC. We are trying to run the printer connected via parallel cable to a Win2K PC and shared over the network to which the MAC is connected. Can connect to shared printer from MAC and have tried using the HP 1220C Gimp 4.2.5 (from memory) configuraton available in the MAC library at the MAC end. A3 printing works but is of terrible quality with aliassed lines and broken lines where they should be solid. I have tried using HP's Version 2 and Version 1 driver on the PC but get the same results. From other postings I can see that it is possible that the VW print options are not optimally set, but I know nothing about running VW.
Any advice on getting this setup to work would be greatly appreciated.
Steve Berger
1 answer to this question
