Ben Clayton
Waste paper after plotting.
I am using a Designjet 1055CM Plus plotter, with VW11.5 (PC), after a number of prints have been sent to the plotter at A1, I start to receive an additional A0 sheet from the plotter after every sucessful print, with the text:-
"ERROR: undefined
OFFENDING COMMAND:
STACK:"
The plotter says that an error has occured and press enter to continue flushing the job.
Any advice with regard to this would be helpful!
Cheers
Ben
2 answers to this question
The most common cause of these Postscript errors is a small setting on your studio computer that is easy to fix. Here's how to do it:
1. Go to the Start menu, choose Settings, and choose Printers.
Right-click on "Your Plotter" and choose Properties.
2. Click once on the Device Settings tab.
3.Scroll down until you see "Send Ctrl-D after each job".
Change this setting to No.
4. Click OK.
G-Pang
