I send files to a local print bureau for my large format printing (no in house plotter). In Vectorworks 11.5 and MacOS 10.3.9 if I choose Print:Save as File: Postscript in a large sheet, say US Arch E, the resulting file shows only part of the page. Usually the lower left area - about equivalent to a letter or legal sheet.
Print:Save as File:PDF or Print:Save as PDF return full image, but do not come in at scale. They end up a bit small .998 which translates to a 1/16 of an inch for every 4 feet - bad for full scale cartoon of 40 foot long mural). I can rescale objects in the drawing to compensate, but there should be a way to get the whole sheet in a Save as File:Postscript file. In letter sized tests the Save as File:Postscript file opened as pdf in Apple's Preview and when saved as pdf results in a properly scaled print.
Any experience with this problem?
Here is my drawing set up in VW:
one layer, one class
File Menu: Page setup:custom paper size: 48" x 36", scale 100% (I tried both landscape and portrait orientations - same problem)
Page Menu:Set print area:Arch E (it reverts to "one page"), show page boundary, show page breaks
Thanks
-B
