I've got an unusual problem that I hope someone can help with.
I'm a paper-engineer who uses Vectorworks for designing children's pop-up books. I'm running Vectorworks 10.5.1 on Mac OS 10.3.9.
I used to print out my prototype outlines onto card and then cut them out by hand using a scalpel, but I've recently bought a Summacut D60 signwriter's vinyl cutter that will do the cutting for me. The cutter is essentially a plotter that uses a tiny knife instead of a pen.
At the moment I have to export my cutting outlines from Vectorworks as epsfs so that I can import them into the signwriting software (called MacSign) that drives the cutter. The cutter driver is an integral part of the signwriter software and can't be accessed directly by other applications. Unfortunately the cutter manufacturer does not produce an independent driver for Mac OS X, which is why I currently have to use this roundabout route.
However I notice that the cutter control language can be reset to HP-GL/2, so if I could get a HP-GL2 driver for Mac OS 10.3.9, I might be able to cut/plot directly from Vectorworks.
Can anybody tell me how I could get hold of such a driver?
