B&W Printing SOLVED!!
Ramon PG
6 answers to this question
actually that preferences command does allow you to print black & white. i use it often when i batch print (we have a custom script that changes view to b&w and adds a file name and print date to each sheet, that does not work with batch print).
I guess I stand corrected.
But for some strange reason everytime I tried to print with checked "Black and White Only" I got grayscale. Even stranger, up to now everyone in the techboard told me to just use dark colors when drawing and experiment.
I took me some more time, but at least it's settled.
Its easy to print drawings as black and white only.
Simply select "File/Preferences/Document Preferences" and check "Black and White Only."
You can also print using the "Layer Colors" option to easily control more complex scenarios with some layers appearing in black and white only and some in color.
If you open the 'Help" menu and type in "Black and White" it will outline additional options.
[ 05-09-2005, 12:21 PM: Message edited by: CEA ]
