Ramon PG 0 Posted May 9, 2005 I hope this is not extremely redundant... As a new VW user it certainly was frustrating and took me a lot of time to find this out. 1. To be able to print to B&W use the Batch Print under the File menu. Thanks to Mike Moore for that. 2. To batch print to PDF use the Resolve plug-ins recommended by Steve CAG. Here' the link: http://www.resolve.ca/addons.html Isn't the i-net fantastic ! Quote Share this post Link to post
0 Ramon PG 0 Posted May 9, 2005 quote: Originally posted by CEA: Its easy to print drawings as black and white only. Simply select "File/Preferences/Document Preferences" and check "Black and White Only." I don't think that prints b&w. Only makes your tools draw black. Quote Share this post Link to post
0 Kevin 1 Posted May 9, 2005 Actually Ramon, CEA is right. Just try it with printing to a PDF and you will see. WYSIWYG. Quote Share this post Link to post
0 jfmarch 0 Posted May 9, 2005 actually that preferences command does allow you to print black & white. i use it often when i batch print (we have a custom script that changes view to b&w and adds a file name and print date to each sheet, that does not work with batch print). Quote Share this post Link to post
0 Ramon PG 0 Posted May 9, 2005 I guess I stand corrected. But for some strange reason everytime I tried to print with checked "Black and White Only" I got grayscale. Even stranger, up to now everyone in the techboard told me to just use dark colors when drawing and experiment. I took me some more time, but at least it's settled. Quote Share this post Link to post
0 CEA 0 Posted May 10, 2005 Its easy to print drawings as black and white only. Simply select "File/Preferences/Document Preferences" and check "Black and White Only." You can also print using the "Layer Colors" option to easily control more complex scenarios with some layers appearing in black and white only and some in color. If you open the 'Help" menu and type in "Black and White" it will outline additional options. [ 05-09-2005, 12:21 PM: Message edited by: CEA ] Quote Share this post Link to post
0 Ramon PG 0 Posted May 11, 2005 I suspect my poor output might have been a product of the low default dpi output. but i can't be sure. Quote Share this post Link to post
