LarryAZ
Batch print trims little strips between sheets
I have a weird problem. I finally figured out how to get batch print to work correctly from sheet to sheet. But now my HP 130nr "D" size roll is printing a sheet just fine and then trimming three little strips of paper about 3/8" each before it starts the next sheet. I get exactly 3 strips between every sheet.
Anyone ever heard of this one?
2 answers to this question
Are you printing Viewports or design layers?
If a viewport, check the page setup information so that it says ONE PAGE. Do the same under Page>Set Print Area if you are printing saved views or design layers.
It sounds like you have D sheet size selected in the print area, which is not correct. It needs to be set to ONE PAGE to allow for margins. Leaving it at D as the set print area will print separate pages for the margins.
Katie you were right it was set to D size and you can tell by the little icon that it leaves tiny strips on the edges. I'll try it out the next time I print, but I'm sure you diagnosed the problem. This one would have been difficult to figure out.
Thank you very much.
