For several hours now, I have been trying to print to an Epson 2200 at 11x17 in OS X.2. I'm having several troubles:
The first is that I'm trying to print a sheet layer. When I set the print area to 11x17, it tells me I need 4 sheets to print the drawing, whcih is set for an 11x17 sheet. I can manually reduce the size to 10.5x16.25, but that doesn't seem to matter because...
The first time I printed, it worked ok, except I had checked "Print current view only" so it scaled my 11x17 down to fit the print area of an 11x17 sheet, so the scale was completely off, so...
I tried printing just the first of 4 pages at 11x17 with the "print current view only" box unchecked and all that happens is the 2200 spits out severl blank pieces of paper before loading one, which it then decides is not properly ejected, which stops the printer.
I have downloaded the current drivers for the printer as well as gimp-print, but none seem to do the trick. I also have an Espon 1520, but it's not setting up easily.
jarjones
Any help would be greatly appreciated.
Jeff
2 answers to this question
