We have a file which had been started on a Mac, then worked on from a PC. Some objects will not print from Windows, but will print from Macs. The thing I can find that the non-printing objects have in common is that they have records.
The file was started with all walls drawn using the "wall tool". It was then worked on from a PC, with walls drawn using the "wall type tool". All the walls drawn on the PC will not print from Windows. They will print correctly from macs, though. They have records.
Room names (with records) don't print from Windows, either.
Both machines are running VW11. Plotting to an HP800PS. We've never run into this before.
Any suggestions would be appreciated!
