24x36 PDF's
BillMac
2 answers to this question
You need to add a large format printer to your print center. This has been discussed before and you may be able to find the threads with a search.
Your system software may already have those descriptions. Gimp-Print can provide those and I believe you can download them from HP.
I had the same issue. I called my service bureau and got the make and model of their large format printer (in my case an HP 755c). I then went to the HP website, and downloaded the appropriate printer driver. I just make sure that the HP is selected as my printer when "printing" for my service bureau. That's all there is to it. Save to pdf from the print dialog box, and you should be good to go.
