bjoerka Posted April 8 Share Posted April 8 I have a speaker (d&b e5) hanging at 7m, tilt is set to -90 degrees, throwdistance set to 7,5m and the dispersion hatch is not showing up. Changing the tilt angle solves the problem, but only when i go to -83 degrees, from -84 the hatch disappears. Known problem or mine ´cause i am doing something wrong? specs like in my signature Quote Link to comment
C. Andrew Dunning Posted April 8 Share Posted April 8 7 hours ago, bjoerka said: I have a speaker (d&b e5) hanging at 7m, tilt is set to -90 degrees, throwdistance set to 7,5m and the dispersion hatch is not showing up. Changing the tilt angle solves the problem, but only when i go to -83 degrees, from -84 the hatch disappears. Would you mind posting or DMing me a copy of your file? 1 Quote Link to comment
bjoerka Posted April 8 Author Share Posted April 8 I´ll send you a link to download the actual file via DM in a few minutes. There is a saved view which brings you back to my layers and classes settings when you are testing something. Quote Link to comment
C. Andrew Dunning Posted April 9 Share Posted April 9 2 things: 1) Edit the speaker's Symbol definition and change "Throw 1" from "100 ft" to "100'." 2) For each Speaker instance using that Symbol, either switch Symbols and then return to the E5 or enter "100'" in the Range 1 "Throw Distance." The Hatch is not being applied because the Throw Distance you are using is shorter than the given dispersion lines. 100' is way more than you need but the tool will "trim" that automatically at your Listening Height. I hope that helps. 1 Quote Link to comment
