ConnectCAD - Create Devices By Script
Hello, I'm imagining this is one for @Conrad Preen and @Nikolay Zhelyazkov, hope you guys are well.
I have a need to create Devices from a list of items coming from an external source. The Devices will all be things in our library - so 3D symbols with the attached Device Def Record.
Is this possible at the moment? I can do it with Equipment Items, but Devices seems a step further. I'm presuming I would start with CreateCustomObjectN, but unsure after that.
Failing that, it would have to be:
- Import required symbol resource
- Read CC Def record
- Use CC_DeviceFromShape to make a Device of the correct height
- Programmatically insert required sockets inside the profile group (the profile group of Devices always confuses me)
If there is anything on the way for this soon then it would be useful to know, please, before I go down the rabbit hole!
Many thanks,
Simon
Hello @spettitt,
Have you tried using Create Devices from Worksheet menu command? It takes a worksheet/list and creates the devices from it. If the devices are known to ConnectCAD (aka make/model is present in the device builder) then the created devices use the definition and get created with the correct sockets and data.
Best Regards,
Nikolay Zhelyazkov
57 minutes ago, Nikolay Zhelyazkov said:
Hello @spettitt,
Best Regards,
Nikolay Zhelyazkov
I have used it before yes, but from memory I think it just creates a pool of devices together. The incoming information will know which rack, location etc each device is in, so I was hoping to programmatically insert them on Layers and set their position from script. I'll have another go with it though. Thanks
