D5 use in Vectorworks ends up with a crash, every time.
Hello all.
I have been using D5 for a while now, and with the latest VWX release, 2026 4.0.1, if I want to use the D5 tool, everything works fine. Until I go back to VWX and try to turn off the tool. Then it's a hard crash to desktop. Every time. Doesn't matter what file, I've tried 5. Doesn't matter the order; Close D5 before returning to VWX, Leave D5 open, Close the D5 project file. When I tried closing the VWX file, it also crashed without saving.
Any thoughts?
TYIA
Hi, I tried it:
1. Models with/without textures can be synced to the D5Render normally.
2. If the material contains textures, and an abnormal linkage state such as colsing D5Render/disconnecting linkage during the linkage process, VW will shut down abnormally (no material/solid color material will work normally).
Is this the case?
Thank you yuefei
In my case as I stop the link or pass to a plan view, crash is immediate
And yes, I have 2 or 3 different links from Vectorworks
This is necessary in order to split the model into smaller parts: say fixed parts vs variable ones
(I think we all are waiting for the possibility of managing the imported objects individually as in Twinmotion)
What I'm wondering is if Dropbox syncing can affect somehow, but till now didn't cause any problem
Also I'm using an external SSD for D5 resources
Do you use Dropbox, too?
