Problem with "ForEachObjectAtPoint".
Hi everyone,
I'm having a problem with the "ForEachObjectAtPoint" function.
I need to explore one of the objects and define its object type.
The script I created works fine on design layers.
It behaves strangely in ViewPorts. If I'm in top view, it works, but if I'm in another view, it doesn't.
Does anyone have any ideas?
Thanks everyone
Procedure Taggit;
{Creato il 26 /03/2026}
VAR
    Scala                         :REAL;
    g                            :POINT;
    viewportHandle,VPGroupH        :HANDLE;
    proseguo,proseguo2            :Boolean;
    Tipo_L                        :INTEGER;
FUNCTION IN_VPort(h1 :HANDLE) :BOOLEAN;
VAR
    tmp_B            :BOOLEAN;
    tag                :string;
    DataTagH        :HANDLE;
BEGIN
    tag:=Num2Str(0,GetTypeN(h1));
    TextOrigin(g.x*Scala, g.y*Scala);
    TextSize(10*Scala);
    CreateText(tag);
    DataTagH := LNewObj;
    tmp_B:= AddVPAnnotationObject( viewportHandle, DataTagH);
    proseguo2:=True;
    ReDraw;
END;
{fine funzione per ViewPort}
FUNCTION IN_Lucido(h1 :HANDLE) :BOOLEAN;
VAR
    tag                :string;
    DataTagH        :HANDLE;
BEGIN
    TextOrigin(g.x, g.y);
    TextSize(10);
    CreateText(tag);
    proseguo2:=True;
    ReDraw;
END;
{fine funzione per Lucido}
BEGIN
    proseguo2:=false;
    Tipo_L:=GetObjectVariableInt(ActLayer, 154); {message ('tipo lucido :',ii,' Nome :',GetLName(ActLayer));}
    Case Tipo_L of
    1:BEGIN  {lucido design}
        Scala:=GetLScale(ActLayer);
        proseguo:=True;
        WHILE proseguo=TRUE DO BEGIN
            GetPt(g.x,g.y);
            ForEachObjectAtPoint(IN_Lucido, 0, 1, g.x, g.y, 0.05);
            if (proseguo2=True) THEN
            begin
                proseguo:=YNDialog('Continuo?');
            end else BEGIN
                proseguo:=YNDialog('nessun oggetto selezionato. Continuo?');
            end;
        end;
    end;
    2:BEGIN     {lucido presentazione}
        ViewportHandle := LSActLayer;
        Scala:=GetObjectVariableReal(ViewportHandle, 1003);
        If ViewportHandle=NIL THEN
        BEGIN
            AlrtDialog('Seleziona una viewport!');
            Sysbeep;
        END ELSE BEGIN
            VPGroupH:= GetVPGroup( viewportHandle,2);
            proseguo:=True;
                GetPt(g.x,g.y);
                ForEachObjectAtPoint(IN_VPort, 1, 1, g.x, g.y, 1);
                begin
                end else BEGIN
                end;
            end;
            ResetBBox(VPGroupH);
            UpdateVP( VPGroupH);
            ResetObject(VPGroupH);
        END;
    end;
    OTHERWISE
        BEGIN
            {x completezza}
        end;
    end;
    Redrawall;
END;
Run(Taggit);
Test.vwx
Hi everyone,
I think I solved the problem in a somewhat unstructured way.
1. I create a resource list with the layers using BuildResourceList
2. From that list, I remove the layers that aren't in the VP using GetVPLayerVisibility
3. With an active loop, I select the VP layers one at a time, setting the same view as the VP using SetViewMatrix, on which I execute ForEachObjectAtPoint
It seems to work.
