Stair Tool
I am using the stair tool in the scenic elements pallete, and I am wondering if it is possible to make the railings have posts going from them to the stairs. As it stands, when i turn on the railings they float 3' above the stairs.
Any help would be greatly appreciated.
You'll need to use the handrail tool.
Once the handrail has all the definitions set in the OIP, you'll need to ungroup it to rotate it to follow the angle of the stairs.
Then rotate it the degree of the stairs.
