Jon Howard
Missing layers in Panther 10.3.2
I am printing to an HP DJ 450c via ethernet, from VW9.5.2. I am using OS 10.3.2.
I can set up the printer using CUPS, and have upgraded the GIMP software to 4.2.6.
The problem I have that is several layers of the drawing fail to print, typically black layers such as titleblocks etc.
Any ideas what is going wrong?
Jonathan
2 answers to this question
Update to VW 9.5.3 to see if that resolves the problem. You should NOT be using VW 9.5.2 or earlier under OS 10 because of a bug that affected the drawing.
Thanks, Katie. I will give that a try...
Mind you, it would help if the black cartridge in the plotter hadn't actually stopped working...
Oops.
Jonathan
