the frog Posted March 11 Share Posted March 11 Hello I found a strange behavior of the dim nodes in enveloppe scripts. If you make a script, give a name to the dim node and then enveloppe (this is the base), when you copy the enveloppe to use it somewhere else and change the Dim node value without changing the node name, everything is fine. When you finish your script make the object it is still fine. BUT when you copy the object… The values of the Dim nodes with the same name change values to pick up one of the value (I guess the first one in the Vector script text file) and apply it to the other nodes. Of course, the copy object looks bizarre! I found it while working on the Ikea cabinet I just posted. It took me hours to find the pb and change the names. Quote Link to comment
