rbraun
crashes
I'm using vw10 with a hp designjet100. The program crashes with a type 2 error message
after printing. any thoughts?
4 answers to this question
The print file is probably larger in VW 10 because of the growing precision and file sizes.
There's not much you can do. Although, you should be running OS 9.2.2 for carbon lib optimization. You may find better results using that.
If you are running other applications, try to close them. You may want to try and lower the memory partition in VW to allow more memory for the file to spool.
If your VW file is of significant size and you think these file sizes are the norm for you, you should look into additional memory.
I think the min memory requirements for VW are 256 if you are running VW and RW or any of the IP products and more if you are running the IP products and renderworks.
Error Type 2 is memory related.
What version of OS 9 are you using?
How much built in memory do you have?
