SHEET SIZE PLOTTING PROBLEMS
gerry_dup1
I'm having the same problem that Gerry had. I followed the steps above, and it worked perfectly, but for only one print. Now when I go to File--Print, Vectorworks crashes every time. And it's not just when I'm sending something to the HP800ps. If I go into page setup and pick a different printer, it still crashes when i go to File--Print.
I'm not having any problems printing from other programs. And I've also discovered that if I delete the HP800 from the printer list, I can print from VW to any of the other printers again.
Any solutions?
thanks
It sounds like you have a problem with the way the 800 is installed.
You may want to try running disk utility to see if that remedies the problem - run it after you reinstall the printer.
You may also remedy the problem by updating to OS 10.3.6.
If these suggestions still don't address the problem, you'll need to contact Apple.
