Peter Telleman Posted February 12 Share Posted February 12 @Scott C. Parker Hi everyone, I hope an easy to fix question. If I use the stage deck tool with the deck only option, the height is 150mm. Most of the decks we use here are 90mm thick, is there a setting where I can change this? thanks, Peter. Quote Link to comment
C. Andrew Dunning Posted February 12 Share Posted February 12 8 minutes ago, Peter Telleman said: I hope an easy to fix question. If I use the stage deck tool with the deck only option, the height is 150mm. Most of the decks we use here are 90mm thick, is there a setting where I can change this? "Height" is the height of the top face from the Layer Plane (floor). "Top Thickness" is the thickness of the main area of the deck. "Trim Height" is the height/thickness of the trim around the edge of the deck. All should be adjustable when you have chosen "Deck Only." 2 Quote Link to comment
Peter Telleman Posted February 13 Author Share Posted February 13 @C. Andrew Dunning thanks a million, quick follow up question. There seems to be a minimum size in the tool. When I try to make a 250x250 deck, it doesn't want to make the with smaller than 305mm. Another easy setting thing? thanks a lot, Peter Quote Link to comment
C. Andrew Dunning Posted February 13 Share Posted February 13 6 hours ago, Peter Telleman said: @C. Andrew Dunning thanks a million, quick follow up question. There seems to be a minimum size in the tool. When I try to make a 250x250 deck, it doesn't want to make the with smaller than 305mm. Another easy setting thing? For rectangular decks the minimum deck width and depth are 12" and 8" (305mm and 203mm). 1 Quote Link to comment
