hide wall lines
I don't seem to be able to hide wall lines in plan view when creating openings. instead I get red lines. I've tried changing the 2d visualisation attributes but this doesn't have any effect. in version 2025 there was an option to hide the wall lines but this has disappeared in version 2026, what am I missing?
I suspect your Walls extend below the bottom of the Doors + therefore the red lines are Wall geometry seen below the cut plane, the attributes + visibility of which is controlled by the Attributes Below Cut Plane class. See the 'Wall Attributes' dialog if it's a styled Wall or the 'Bel Attr Cls' setting in the OIP if it's unstyled.
Similar lines can be generated by the Doors themselves via the Header + Wall Lines parts ('2D Visualisation' pane) but I don't think that's what you're seeing here. Could say for sure if you posted a file.
There are lots of threads on the changes to Walls in VW2026 plus a post + video on the Knowledgebase + another video on the University.
yep the walls did extend below the bottom of the doors so I've raised the base of the walls to equal the doors. When i put a window in I get the same problem and the only way I can overcome this is to add the cill, why have things been changed, is there a benefit?
As I said the geometry is controlled by the Attributes Below Cut Plane class so make a class, assign the geometry to it then change the attributes so looks the way you want or turn the class off.
Yes. Walls needed reengineering so they worked more efficiently under the hood. This will allow new features to be incorporated more quickly/easily + things such as sloping walls to be developed in future. The Top/Plan graphics are now derived from the 3D geometry whereas previously (bizarrely) it was the other way around.
according to the instructional videos the Attributes Below Cut Plan should be able to be selected from the Object Info Palette but as you can see from the screen grab this item is greyed out, I eventually found the option in the Edit Wall Style palette under Edit Wall attributes, should i be able to select the class from here?
If the Wall is styled the 'Bel Attr Cls' setting in the OIP is greyed-out because it is controlled by style not by instance. If you unstyle the Wall the 'Bel Attr Cls' setting becomes editable.
6 minutes ago, beanus said:
I think I get it now, the wall lines show in design layers but not in but not in the viewports in sheet layers where they can be turned on and off
'Wall lines' can be one of three different things:
1) the Wall itself viewed below the cut plane
2) the 'Header' part of a Door or Window
3) the 'Wall Lines' part of a Door or Window
There is no difference between the Design Layer or a Viewport in times of how any of this geometry displays, it's just that you can have different class or detail level settings for your Viewport.
Post a file.
But what you need to do is go into the settings for your Door or Window + in the 2D Visualisation pane put the 'Header' part in one class (e.g. 'Door-Header') + the 'Wall Lines' part in another class (e.g. 'Door-Wall Lines'). Now toggle each of those classes on + off + edit the attributes + it should be clear where the lines you're seeing are coming from.
The Wall Lines geometry can also be completely turned off by setting it to invisible at all detail levels in the Detail Levels pane (which I'd advise doing, and just relying on the Header part if you want to do a RCP).
