mort2
Hp 500ps problems
having problems with printing to a HP 500ps from an Apple. We are using an old Mac as the print spooler, and it has worked in the past. We loaded VW 10.5 and Apples upgraded OS,now only a small corner of the drawing comes out. Tried creating PDF files, and they look normal. Old plot files created before the upgrade appear to work fine. [Confused]
1 answer to this question
It sounds like you need the clear print settings script to clear out any stored data.
You can obtain this by contact either your local distributor if you are outside of the US or if you are in the US - tech support at tech@nemetschek.net.
They can email the script as well as directions to get the problem resolved for you.
