Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
C. Deel
occasional large blocks of black ink
Using VW Architect 10.1.2 and Gimp-Print 4.2.5:
At apparently random intervals, our plots (from an HP 455CA and an HP 430) come out like this:
The drawing we plotted is there, but all compressed along the top couple inches of the sheet (along the long edge). The rest of the sheet is full of 100% black with a few thin white breaks in it (running lengthwise). This makes a mess and uses tons of ink. We can basically determine no pattern to when this occurs.
I'm not sure whether to blame VW, Gimp-Print, or our network hardware.
Has ANYBODY else seen this behavior?
Thanks,
Chris
6 answers to this question
I have a 455CA but am using VW9.5.3, OS10.2.3 and Gimp Print 4.2.4. I have not had any problems. You might try using 4.2.4 instead of 4.2.5 and see if there is an improvement.
we've had the same problem- usually restarting the plotter works... i think it's a problem with gimp print.
-mgt
Have you noticed any pattern to when it happens?
It's kind of a horrible error since it wastes so much ink.
The Gimp-Print bug list doesn't seem to have anything on this; maybe I will post on there.
CD
have the same problem with the same plotter (hp 455ca).
my OS is Win XP and anytime i try to print any entity that is not solid (a pattern or a hatch), everything turns into black. i've tried to print the same file on a win 98 and everythign was OK. i though it was an issue about Win XP and VW 9. i tried the VW Viewer 10 and the same problems occur. i guess my plotter is kinda old... i haven't check any driver updates, might be it.
sometimes text boxes print jambled too, when it happens i stop the process and unckeck 'scale text' in the 'layers' tab. always works.
Checkmark "Print Patterns at on screen resolution" in the print dialog box.
