I now work exclusively in a rotated view on all projects, and while there have been improvements to this workflow, I still find myself in an unrotated view far too often, which has caused real problems whereby colleagues have been working on a file unaware that they're in an unrotated view; this is exacerbated by projects that are rotated by a very small amount (e.g. 0.13 degrees).
One is problem is that certain actions unrotate the view temporarily, such as editing a slab modifier. I don't want to be in an unrotated view when I'm editing a slab modifier, but at least it returns me to a rotated view when I exit.
The other, more serious problem, is that certain sequences of work will unrotate the view permanently. For example:
Start in a rotated Top/Plan view on a design layer.
Go to a Section Viewport (e.g. a building elevation or section) on a Sheet and edit the Crop, Annotations, or a Design Layer (with the Navigate back to viewport option on).
Exit, then head back to a Design Layer and you will see that the view is now unrotated. Only edit Section In-Place retains the rotated view.
This is just one example. There are probably more.
It seems to me there might be a few ways to fix this once and for all (in my order of preference):
Provide a Document Preference for a permanent plan rotation. Even double-tapping the Top/Plan shortcut would leave you in a rotated view. To get into an unrotated view you would need to deactivate the Document Preference.
Give us the ability to lock and unlock the plan rotation. You would need to explicitly unlock the rotated view before double-tapping the Top/Plan shortcut (or any other action for that matter) would take you to an unrotated view.
Find all the actions that unrotate the view and stop them from doing it. (I don't like this this option option because could take a decade to implement fully)
Christiaan
7 answers to this question
