data visualization and door/window openings refresher
jnr
using data visualization for a presentation where walls are simply gray fill. some door and window openings are appearing solid. Suspect this is the hangover from 2025 to 2026 where wall fills went haywire. Can't remember how to turn off the fill in the door opening.  apologize for the plan rotation but this is the same opening. Note the white fill only appeared when the file went from 2025 to 2026. Suspect that the issue is not the data visualization.
thoughts?
6 answers to this question
19 hours ago, jnr said:
set everything below cut plane to nonplot and turned it off.
So to confirm we're talking this in the case of an unstyled Wall:
Or this if it's styled:
And are you really using Update 1 or the most recent one? Because in Update 1 turning the class off didn't work. You had to set pen + fill to none instead. Update 2 onwards (I believe) the class controlled visibility as well, not just attributes.
