I’m having issues with the scale and units of a DWG file. It seems the original is at 1:75, and the document units are set to mm. However, even after I tried to put the design layer as 1:1 it keeps showing the length in meters? Or something like meters, it keeps rounding it up and only showing whole numbers.
The sheet layer is even worse, as when I wanted to measure the length of a line, it says the scale is 13 5879941/176400?? The length is still just 18, although I can’t tell what it thinks “18” is.
I’ve never had issues with inserting a DWG before, so I’m not sure if it’s maybe an issue with the original document.
stanemi15
1 answer to this question
