I am trying to set the Print Area to a length greater than 2538mm which seems to be maximum length you can can select. Printer is a 1055c plotter and you adjust the paper size for whatever length you want(on a roll), but when you go and set the print area after it only goes across 2538mm. Typing in anything longer doesnt seem to work. I am using VW 8.5.2 on Windows ME.
Hope there is some solution
Thanks
