  • 6
2D view of Cut and Fill is NECESSARY for landscape architects (make it easier)
Anna Arbetter
11 answers to this question
On 1/2/2026 at 9:32 AM, Katarina Ollikainen said:
@yasin2ray, I fully agree - a 2D view of c&f is required. We're working on this, together with improvements in how the areas are displayed, and also how to retrieve more volume and area information from the map.
Fantastic! We need all of those things. I hope they come through soon. Thanks for informing us of these upcoming updates.
I would like to add Depth to that, a grid with numbers showing depth of change (like what is produced in AutoCad Civil 3D).
Anna
All very good ideas @HebHeb! We're doing a lot of projects with basically just cut&fill calculations for large areas in early stages and I hate that we always have to go with Civil3D for those.
It would also tie this to the planned feature of site model phasing. I've got a bunch of projects where my customer is looking for cut&fill for just the first stage of excavation for the buildings foundation, with proper slopes according to geotechnical requirements. The cut&fill for landscaping would be handled separately. Unfortunately he's getting it done elsewhere now in Geo Professional because it's so much faster and has better tools.
@Anna Arbetter have you tried the 2D Cut  Fill Area option in the Site Model Graphic Properties.
It's not an ideal solution at present, but it might offer a simpler alternative to the 3D approach you've described.
Its current limitations are:
  1. The site model needs a solid fill for the cut & fill areas to be visible, which is a problem if you want objects & layers below the site model to be visible on your plan (e.g. aerial photos). A possible workaround is to stack two viewports on your sheet layer.
  2. As noted below the 2D Cut  Fill Area checkbox, the colored polygons are placed on top of the site model, obscuring the contour lines. A workaround for this is to Create a Snapshot of the site model, set its fill to None, and stack it above the working site model.
To improve 2D Cut & Fill function I'd be suggesting:
  • Make the 2D Cut & Fill display independent of the Site Model fill opacity, ideally with it's own opacity setting in the Site Model Graphic Properties window.
  • Stack the 2D Cut & Fill polygons below the site model contour lines, labels, etc.
  • Add the missing '&' to the text description beside the checkbox (and remove the duplicate '&'s from the Site Model Net C&&F Volume and Total C&&F Volume field headings).
Edited by MethodDesign
Clarity
@MethodDesign I'm not sure what you mean be "2D Cut Fill Area option...as an alternative to the 3D approach". Checking that box creates the graphics for Cut and Fill. The view of Cut and Fill can only be seen in a 3D view (Top, etc. Not in Top/Plan).
Anna
Anna
Hi @Anna Arbetter
The 2D Cut Fill Area check box found in the Site Analysis tab of the Graphic Properties popout window in Site Model Settings (screenshots in my previous post), is a 2D representation that is only visible in Top/Plan view, provided that the Fill Style of the Site Model is set to Solid. See screenshot below and example .vwx file attached.
The 2D Cut Fill Area setting is entirely separate to the Cut and Fill 3D Display mode that can be selected in the main Site Model Settings window, and the two can be used independently. Their color settings are also independent of eachother.
The 2D option is quite unintuitively hidden away in comparison to the 3D option, and it has been this way for many years. I assume the rationale is that it's a form of 'Site Analysis'.
My further suggestions for the improvement of Site Model Cut & Fill representation would be:
  • The 2D Cut & Fill Area should be made equally accessible and intuitive to find as the Cut and Fill 3D Display mode.
  • The 2D and 3D Cut & Fill representations should generate results that are consistent with eachother.
  • There should be an additional 3D display option which shows areas of Cut & Fill draped over the proposed 3D terrain, as opposed to the current option which converts the site model to a flat plane with 3D Cut & Fill volumes shown relative to it.
260128_VW26_Landmark_2D Cut & Fill Example.vwx
