SMBD Posted December 13, 2002 Share Posted December 13, 2002 VW10 to HP1220, will not allow me to make multiple prints only ever prints one copy! is this a fault? or my error? Quote Link to comment
0 Guest Posted December 13, 2002 Share Posted December 13, 2002 What OS are you using? Is this the deskjet or the laser jet? What exact model of the 1220 are you using? [ 12-13-2002, 09:23 AM: Message edited by: Katie ] Quote Link to comment
0 SMBD Posted December 13, 2002 Author Share Posted December 13, 2002 quote: Originally posted by Katie: What OS are you using? Is this the deskjet or the laser jet? What exact model of the 1220 are you using? OP Windows XP Deskjet 1220c Quote Link to comment
0 Guest Posted December 14, 2002 Share Posted December 14, 2002 ARe you using driver version 2.1 released Nov 27th, 2.0 or the one built into windows xp? Quote Link to comment
0 SMBD Posted December 16, 2002 Author Share Posted December 16, 2002 quote: Originally posted by Katie: ARe you using driver version 2.1 released Nov 27th, 2.0 or the one built into windows xp? orig. when I contacted you, driver built into windows xp. I have just down loaded an updated driver from hp ref hpsfx32 v1. this has made no diff, still only single copy printed! Quote Link to comment
0 Guest Posted December 16, 2002 Share Posted December 16, 2002 Can you duplicate this problem from other applications? Quote Link to comment
0 SMBD Posted December 16, 2002 Author Share Posted December 16, 2002 quote: Originally posted by Katie: Can you duplicate this problem from other applications? no, only occurs in vectorworks v10 Quote Link to comment
0 Ronan Fitzgerald Posted March 28, 2003 Share Posted March 28, 2003 Hi, Two offices which I support are having this same issue: HP Deskjet 1220c, using the built-in windows XP driver not able to print multiple pages. However, we cannot use the v2.1 driver, as this crashes VW 10 everytime we print. I don't know if the crashing issue has been fixed in VW 10.1.0 from 10.0.0 or 10.0.1, so I may try that soon. The main network that I have tried this on has consisted of about 20 Win2k SP3 machines, 3 WinXP SP1 machines, and a DeskJet 1220C through a 3 port JetDirect box, connected via IPX/SPX Many thanks for any assistance... Ronan P.S. We are also suffering from the many DesignJet 500 problems, but I won't go into them... Quote Link to comment
0 Guest Posted March 28, 2003 Share Posted March 28, 2003 You will need to download the 2.1 version printer driver from HP.com. Crashing and printing only one page at a time are two things addressed by this new driver. You need to completely remove the old printer setup in the printers folder BEFORE installing this new driver and setting it up. This is HP's suggested fix for the mentioned problems. Quote Link to comment
0 Ronan Fitzgerald Posted May 1, 2003 Share Posted May 1, 2003 Hi Katie, How does one remove the old driver completely? From what I know, you can go into the printers folder, right click, go to server properties and remove from there. I will try this a little later, and get back to you all on it. Quote Link to comment
0 Guest Posted May 1, 2003 Share Posted May 1, 2003 The 2.1 driver isn't at Hp anymore. If you want this driver, email me and I can email it to you. If you are on XP - it's fine to just remove the printer by doing the way you describe. If you are on Win NT or 2k, or Win 98/ME - you'll need to refer to HP's instructions for removing the driver using their scrubber utility. They can be found on HP's website or by contacting them. tech@nemetschek.net?subject=ATTN:Katie [ 05-01-2003, 11:54 AM: Message edited by: Katie ] Quote Link to comment
SMBD
VW10 to HP1220,
10 answers to this question
