Kevin van setten 1999 Posted December 3, 2025 Share Posted December 3, 2025 Hi all, I’m trying to get the standard SDK ObjectExample running as a baseline before starting my own tools, but I’m stuck at the same point in both VW 2025 and 2026. Setup Windows 11 Vectorworks 2025 + 2026 (Spotlight) Visual Studio 2022 (Desktop C++ workload) SDK from GitHub: SDKExamples-master in C:\VWSDK\SDKExamples-master\ What I did Build (2026 example): Opened: C:\VWSDK\SDKExamples-master\Examples2026\ObjectExample\ObjectExample2026.sln Retargeted toolset when prompted → Apply Config: Debug | x64 Build → Build Solution → Build 1 succeeded, 0 failed Output files are created in: ...\Output\2026\_Output\Debug\ObjectExample.vlb ...\Output\2026\_Output\Debug\ObjectExample.vwr Install into VW: Opened VW user Plug-Ins folder via Preferences → User Folders → Explore: C:\Users\<me>\AppData\Roaming\Nemetschek\Vectorworks\2026\Plug-Ins\ Removed any old copies of ObjectExample. Copied ObjectExample.vlb and ObjectExample.vwr directly into that Plug-Ins folder (no subfolder). Restarted Vectorworks. What I see In Plug-in Manager → Developers / Unknown developers I see: ObjectExample.vlb Inside it: Object: Advanced Complex Object Tool: cExtTool So VW clearly loads the library and sees both the object and the tool. The problem In Workspace Editor → Tools (All Tools, correct workspace): I cannot find any tool called cExtTool, ObjectExample, Advanced Complex Object, etc. There is nothing I can drag into a palette. A VectorScript test SetToolByName('cExtTool'); also does nothing (as if the tool doesn’t exist). Exactly the same behaviour happens if I repeat the process with Examples2025\ObjectExample and VW 2025. Questions For the ObjectExample sample, what tool name should appear in the Workspace editor? Is copying only ObjectExample.vlb/.vwr into the user Plug-Ins folder correct, or should I link the whole _Output folder? Has anyone recently built and used ObjectExample successfully on Windows with VW 2025/2026, and if so, what exact steps/names do you see? I just want to get one stock SDK sample fully working to confirm my environment before starting my own Spotlight tools. Thanks for any hints! Quote Link to comment
Stefan Bender Posted December 4, 2025 Share Posted December 4, 2025 Maybe it is a protection issue. IIrc you need to add some protection stuff to the code telling VW which modules are supported. Unsupported plug-ins may not show up in workspace. Quote Link to comment
Stefan Bender Posted December 4, 2025 Share Posted December 4, 2025 Check out macros DEFINE_VWProtection; IMPLEMENT_VWProtection IMPLEMENT_VWProtectionLDF and their use, atm I don't know the details. Quote Link to comment
Stefan Bender Posted December 4, 2025 Share Posted December 4, 2025 The name of the tool should be defined in the tool definition (SToolDef type) that is passed to the constructor of VWExtension tool. Same workflow for menu commands and PIOs. Quote Link to comment
