Michael Siggers Posted December 1 Share Posted December 1 Hi I'm just getting to grips with Marionette and am trying to use User prompts for information. The First question I need to ask to user to enter is the Object Name, but I do not see a User prompt Node for that. The only one I can see is to ask the user for a 'String' Value. When I use this one, my Network fails to find the object, so I have come to the conclusion that I need to convert this String to an Object Name. Would I need to create my own Node from scratch using Python Script to do this? Kind regards Mike Quote Link to comment
Pat Stanford Posted December 1 Share Posted December 1 Does this one do what you want? Quote Link to comment
Michael Siggers Posted December 2 Author Share Posted December 2 28 minutes ago, Pat Stanford said: Does this one do what you want? Hi @Pat Stanford It does, but that's the one I was using originally, but it does not show up a dialogue box asking the user to select the object. On the standalone wrapped marionette it's OK because the information can be entered in the OIP, but I think to use the wrapped network as a Command, it needs the user to be prompted for the various elements. That's why, at this stage, I'm thinking making it a Command did not work, even though it added it to the menu item. For the moment, I'm happy to have it as a Plugin object. Need to learn more about adding it as a Command. Also, now I've added it as a Command, I can not remove it in Workspace settings. Not sure why, so I'm left with a Menu option which is of no use at the moment. Been a productive day, although I feel I've opened a can of worms 😉 Mike Quote Link to comment
Pat Stanford Posted December 2 Share Posted December 2 See this thread for a custom node that allows string input into a Name node. 1 Quote Link to comment
