Mr Punch
Text Spacing/Blank Areas When Printing
We are having some problems when printing from Vectorworks 9.5.2 to our printer, an HP LaserJet8150 under Windows2000.
Firstly text is spacing itself between lines as if set to 1.5 line spacing throughout a drawing, even when set to single line spacing. Identical areas of text print normally when copied to other drawings.
Secondly white/blank rectangles are appearing over areas of drawing when printing but do not appear on the monitor. This seems to be solvable by altering the print scaling factor at the inital print setup box rather than through the advanced settings.
2 answers to this question
Hello anyone there?
In addition to the earlier points is there a way of numerically setting the page, for instance having the bottom left corner on the origin?
Print Setup problem?
When I have the drawing set to print at 50% in the Vectorworks part of the Print Setup dialog it sometimes prints at 100%. This seems to happen when I have failed to check the print setup box before going onto print even when I know that it is set correctly. Is this a print driver/network problem?
HenryWindows2000, HP LaserJet8150, VW9.5.2
