Custom Data Tag
KAAC
Hi All,
I am trying to parse some text that is showing on the ConnectCAD Drop Point annotation data tags. I want to split the cable type text via a Substring function and just use the latter part of the cable type text on the data tag.
I'm trying to do this in the Data Tag definition editor, using the underscores as delimiters, with the below syntax in the definition (see image), it's not working, anybody have any pointers of how to achieve this or what the required syntax is.
Thanks.
  • 3 weeks later...
Your CC_Cabling record is attached to the Data Tag and not to the Drop Point that it is associated with.
The Data Tag will only pull data from the object it is associated with, so you need to store the data with the Drop Point.
Or you can leave the Data Tags as is and just break the associations and then you will get what you want. But if you move the Drop Points, the Data Tag will not move with it.
Also, your Viewport on Sht1 is really weird. It is huge and the drop points are located at about 1.2Million meters from the origin. It appears that there are also other object located at about -1.2Million meters in the other direction, but I was not able to isolate them and zoom in on them to figure out what they are.  There are also about 5 stacked groups that run from the RK1 polygon at about 248,000 meters down to Zero in the Y direction.
Having these objects so far from the origin will also cause you problems in the future, but I don't think that is what is happening with the Data Tags.
