Data Tag_Hanging Position Field
The Hanging Position object doesn't have a length field, and you're actually looking for the aggregated length of the truss items contained in the position.
You could use the Width worksheet formula, as long as the position remains aligned horizontally.
I'll also shamelessly plug Savvy Position Label, which in addition to the label objects, provides worksheet formulae that you can use with data tags.
See
https://benghiatlighting.com/support/docs/savvy_position_label/5.0/function-reference.html
and
https://benghiatlighting.com/support/docs/savvy_position_label/5.0/data-tags.html
They are designed to work consistently across Hanging Position, Truss, Straight Truss, Curved Truss, Pipe, and Ladder objects.
