printing w/1055cm
bgore
I'am using a 1055cm w/ microspot raster and printing from VW 9.5.1 I'am getting fill patterns
that are very pixelated in other words you can see every box that makes up the pattern is there a way to fix the tightness of the patterns and I'am also getting jagged lines in my door symbols frown.gif" border="0
1 answer to this question
The 1055cm is directly supported on the Macintosh, so I'm not sure why you are using MacPlot in this case.
In any event, you should check the resolution setting in the VectorWorks panel of the Page Setup dialog. Make sure the high resolution box is checked and the value is set to something reasonable for the printer. (Not 72 dpi)
Matthew GiampapaNNA Technical Support
