Data tags lose position when hoist snaps to truss
Hey! See file attached below.
I thought i'd finally solved my hoist colouring issue by using data tags with data viz.
Until i actually started making changes to a touring plot made with these said data tags.
It seems as when you snap a hoist to a truss, unless you let your mouse go at the centerline exactly, the data tags will stay at the point you let your mousebutton go.
I'm very much in the habit of using a pipe of the truss as a guide and smartpoints from elsewhere to line things up.
Does not matter if the data tag is locked or not.
Is there any way around this?
I can live with accidentally selecting the tags instead of the hoist, but this is a tad bit to frustrating.
Cheers
Datatag Snapping issue-26.vwx
