PIO in annotations
I have a few PIOs that I created for VW 9/10 that function properly in VW 11 and 12 except in viewport annotations. When in a viewport annotation and a parameter is changed, they redraw improperly. Should I be checking to see if the PIO is in an annotation, and if so, how would this be done? Is there a different origin that I should be aware of?
What do you mean by "redraw improperly"? I've been having a problem with scale issues, but I believe part of the problem is a discrepancy between the viewport scale and the sheet layer (which is at 1:1). If your plug-in checks the layer scale to draw itself, you need to be sure to (a) check whether it's parent is a viewport (or something like this), and then (b) retrieve and use that viewport's scale.
I don't know the exact functions since I haven't hit up this problem yet, but some of the functions I've seen on the VS listserv (this is not working code, just a collection of snippets):
code:
GetParent(h)
GetType(h)
iType : = GetType(GetParent(selObjHandle));
'ForEachObjectInLayer' with 'Visible Objects only'
> Anyone know a VS way to get the current sheet layer dimensions?
Use GetDrawingSizeRect() with the sheet layer active. Here is a
sample of code that I use, with care taken to make sure that layer
scale works for all three possibilities (sheet layer, design layer
and no layer [edit symbol mode]):
IF NOT IsNewCustomObject(gPIOName) THEN BEGIN
s2 := GetLName(ActLayer);
s1 := GetLName(GetLayer(ghParm));
IF (s1 <> '') & (GetType(GetObject(s1)) = 31) THEN Layer(s1)
ELSE s1 := '';
END;
GetDrawingSizeRect(dx1, dy1, dx2, dy2);
r1 := GetLScale(ActLayer);
IF s2 <> '' THEN Layer(s2);
PageWdth := Abs(dx2 - dx1) / r1 * 25.4 / gUPI; { page width in mm }
PageHght := Abs(dy2 - dy1) / r1 * 25.4 / gUPI; { page height in mm }
[/code]
Let me know if you make some headway!
There does not seem to be a way to access the scale set for the viewport. Although this may not be the problem as I tried this on a 1:1 scale viewport and the problem still exists. NNA objects of a similar type (elevation markers, etc.) seem to work properly, so their code has some special magic! But of course we do not access this code, unless someone is listening? [Wink]
Well, this code is magic! Here is the resulting code that seems to work. Any optimizations would be appreciated.
code:
If IsNewCustomObject(ObjectName) THEN
BEGIN
If IsVPGroupContainedObject(objectHand, 2) = TRUE THEN
BEGIN
layerScale:=GetObjectVariableReal(objectHand, 1003);
END
ELSE BEGIN
layerScale:=getLScale(ActLayer);
END
END
ELSE
BEGIN
layerScale:=GetObjectVariableReal(GetVPGroupParent(GetParent(objectHand)), 1003);
END
ELSE BEGIN
layerScale:=getLScale(getLayer(ObjectHand));
END;
[/code]
Thanks.
