Developer Wiki and Function Reference Links Read more... ×
Heath
Labeling x and y coordinates on drawing
I am trying to find a way to display the x and y coordinates of a point on a drawing. I have found a few vector scripts that will do this using the page center 0,0. I need to display x and y coordinates after I have re-set the origin to a different point.
Use the following and subtract these values from your point.
GetOrigin(Xorig, Yorig);
Raymond
MullinRJ
I am not real smart on scripts. I have only used ones the people have shared in this forum. I have never written my own. Here is the script I have. Can you tell me how to add your suggestions?
Thanks a bunch.
Heath
PROCEDURE XYText;
VAR
objectHand, recordHand, wallHand : HANDLE;
objectName : STRING;
X, Y : REAL;
BEGIN
IF GetCustomObjectInfo(objectName, objectHand, recordHand, wallHand) THEN BEGIN {Get Object info}
SetObjectVariableBoolean (objectHand,800,TRUE); {Let the text style be changed by the user from outside}
GetSymLoc(objectHand, X, Y); {Get Object Position}
END;
Locus(0,0); {Something to see, won't print}
TextOrigin (0,0); {Set text position, note the object internal coordinate system)}
FillPat(0); {Set Fill to None}
BeginText;
Concat('E ',Num2StrF(X),' N ',Num2StrF(Y),'' ) {Note there is no ; at the end of this line}
EndText;
END;
RUN (XYText);
In a script that is used in a palette, you can use GetOrigin(), but the script you are copying appears to be headed for a PIO.
GetCustomObjectInfo() is used in PIO's, but not in stand alone scripts.
GetOrigin() doesn't work in PIO's.
It looks like you are trying to make a tool that places a position marker where you click. I will be out for several hours, but if anyone else wants to have a go at this, please have at it.
Raymond
Heath,
This is not the most elegant solution, but it will work in a PIO. Move your origin, create a locus and put it at (0, 0) which is your new origin. In the OIP, go to the DATA pane and give it the name ORIGIN. Any name will do. Lock it.
Then in your script, use:
GetLocPt(GetObject('Origin'), Xorig, Yorig);
These values are then subtracted from X & Y in your Concat statement to adjust your displayed text. (Note, Num2Str is not needed inside Concat.) If you move your origin, you will have to move the named locus to the new origin before updating your PIO's. You can also write a small script to place and lock the reference locus.
The named locus does not have to be on the layer you where are working, nor does it have to be visible. You can place it on a layer of its own and hide it if you like. Then it is out of the way and not likely to get moved accidently. (You can even hide it in a Symbol Definition, if you are careful not to purge unused objects.)
code:
PROCEDURE XYText;
VAR
X, Y, Xorig, Yorig : REAL;
BEGIN
IF GetCustomObjectInfo(objectName, objectHand, recordHand, wallHand) THEN BEGIN { Get Plug-In Object info }
SetObjectVariableBoolean (objectHand, 800, TRUE); { Let the text style be changed by the user from outside }
GetSymLoc(objectHand, X, Y); { Get Object Position }
Locus(0, 0); { Something to see, won't print }
TextOrigin (0, 0); { Set text position, note the object internal coordinate system) }
FillPat(0); { Set Fill to None }
BeginText;
Concat('E ', X-Xorig, ' N ', Y-Yorig) { Note there is no ; at the end of this line }
EndText;
END;
END;
RUN (XYText);
[/code]
HTH,
Raymond
MullinRJ
Thanks so much for the help. This is what I was looking for. The only thing I would like to change is to be able to round to 2 decimal places instead of carrying the number all the way out to 10 decimal places. Is there an easy way to do this? Once again thanks for all the help.
Heath
Heath,
You are welcome. Yes. If your drawing units are set to 2 decimals then you can put back the Num2StrF(X-Xorig) function, but you'll get the units mark appended to the numbers if it is also selected in the Units setup. You may want this. Num2Str(2, X-Xorig) will give you 2 decimals without unit marks appended.
Raymond
