C. Andrew Dunning Posted November 17, 2005 Share Posted November 17, 2005 Good morning! I'm attempting to use a script to reference an already-existing arc to place a path PIO. I'm having a problem getting dimensions from the saved/referenced arc. I've tried GetSegPt1 and HCenter - and GetArc and Get2DPt. The problem is that the PIO is seeing the referenced object as a group and is returning the same values for both the starting point and the arc center - though the start and sweep angles are accurate. Doing the math means that the resulting radius is 0. Do arcs not remain arcs when used as profiles? How can I get the script to "see" the arc correctly? Thanks! C. Andrew Dunning Landru Design - Nashville, TN - cad@landrudesign.com www.landrudesign.com Quote Link to comment
MullinRJ Posted November 18, 2005 Share Posted November 18, 2005 Hi Andrew, What happens if you use: H1 := FInGroup(H); where H is the handle to your supposed ARC? Does H1 point to an ARC? Raymond Quote Link to comment
C. Andrew Dunning Posted November 18, 2005 Author Share Posted November 18, 2005 Raymond - You are a gentleman and a scholar. That is exactly what I needed. Thank you! Quote Link to comment
